1996 Toyota Camry clutch
1996 TOYOTA CAMRY
GLSSMN2U
Transmission problem
1996 Toyota Camry 4 cyl Two Wheel Drive Manual
My camry's clutch stays down when trying to shift. I have to pull it up with my foot and somnetimes the clutch will not engage when i do. any suggestions?
Apr 17, 2009 at 10:55 AM
  • 31,937 POSTS
Hi there,
Check the clutch fluid, i feel that it will be low, if so you will have a leak at the slave cyl at the transmission or master cylinder, this will have to be repaired and re bleed.
Mark (mhpautos)
Apr 17, 2009 at 11:05 AM
