1996 Toyota Camry Car looses power
1996 TOYOTA CAMRY
MROBLEDO
Engine Performance problem
1996 Toyota Camry 6 cyl Front Wheel Drive Manual
Hello, the main seal on my camry needs replacing. It has been leaking oil for some time now. Because I haven't been able to replace it, the mechanic tells me that the clutch needs replacing because oil has spilled over to it. When I star the car and put it in gear, after releasing the clutch it moves very slowly, and then finally it picks up. However lately when I go up a hill even a small one the car looses power. Any suggestions.
Thank you
Dec 18, 2009 at 9:14 AM
Fix the leak and replace the clutch assembly
Dec 18, 2009 at 9:31 AM
