1996 Toyota Camry burn fuse
AJAY1
  • 1996 TOYOTA CAMRY
  • 6 CYL
  • FWD
  • 213,000 MILES
Hi
My 1996 Camry door lock is not working I hear a clicking from the door lock control relay, I open it and find a wire loose, I solder it, when reinstall relay my window 30 amp. Fuse burn all the time. Now no door locks or window working.
Can you help find the problem and repair it.
Thanks.
AJ
Wednesday, July 16th, 2008 AT 7:31 PM
KHLOW2008
  • 41,814 POSTS
Hi ajay1,
Check the soldered wire and see if you had got it wrong or the solder is in contact with anything besides it.
Unplug the windows motor and lock actuators wires and try again, it could be a shorted motor or actuator.
Thursday, July 17th, 2008 AT 1:27 PM
