1996 Toyota Camry '96 Toyota Camry - EGR Valve related to t
JHOFFMANN14
  • 1996 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 141,000 MILES
I received my 1996 Toyota Camry with the check engine light on, and was told that the EGR Valve needs to be replaced. I am also experiencing problems starting the car. The RPM's will not be consistent (or even strong at 1) when I first start the car, unless I press on the gas and force the RPM's up to 1. Sometimes when the engine is warm, the car will try to start and stall, RPM's falling down to 0.
Is this related to the EGR valve? The temperature of the engine does not necessarily always matter.
SOMEONE HELP! :(
Monday, December 28th, 2009 AT 4:57 PM
Could be the EGR valve open it up and clean it out and also the idle air control valve and see what happens that don't work test the throttle position sensor and airflow meter
Tuesday, December 29th, 2009 AT 4:26 AM
