1996 Toyota Camry
NESTA4U
  • 1996 TOYOTA CAMRY
Steering problem
1996 Toyota Camry 4 cyl Front Wheel Drive Automatic 170k miles
My car steering is very stiff like there is no power steering. I changed the pump but there was no change. Is there a way to rule out the steering rack or not? Or is there something else I should look at first. The steering is not completely gone it is very spuratic it use to come and go and be good for a week then bad for a week.
Wednesday, April 23rd, 2008 AT 10:06 PM
  • 31,937 POSTS
Hi there,
If the pump was a new or fully re-co unit and it is adjusted correctly, I would be suspecting the steering rack as there is really nothing else in the system to go wrong, may be best to check for a seized lower ball join, strut bearing plate or faulty tie rod end, there is nothing else to cause a problem, you will just have to have each item checked and ruled out.
Mark (mhpautos)
Wednesday, April 23rd, 2008 AT 11:33 PM
NESTA4U
How can you check the steering rack?
Thursday, April 24th, 2008 AT 5:48 AM
