1995 Toyota Camry Timing
CYBERPIRATE42
Engine Mechanical problem
1995 Toyota Camry 4 cyl Front Wheel Drive Automatic
there r three different notches on the cam gear.which notch do I use to set time and at what angle at top dead center? and also where crank shaft gear how many resoultions do i go around for top dead center? which way do the notches have to face?
Apr 23, 2008 at 7:13 AM
BMRFIXIT
  • 19,053 POSTS
1. check the pics 2. take a note on the cam has a small hole and should be up lining up with the marking on the head
https://images.2carpros.com/forum/automotive_pictures/99387_toyo_4.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_toyota_timing_1.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_toyota_2.jpg
Apr 23, 2008 at 11:23 PM
