1995 Toyota Camry struts
120,000 MILES • 4 CYL • 2WD • AUTOMATIC
BIFFMALIBU
rear right has rattling noise and when hit bump it bangs told it was strut ? so how can tell and how to replace im no pro but know how to follow directions and mechanicly inclined
Jun 30, 2010 at 10:15 AM
BMRFIXIT
  • 19,053 POSTS
Compress and extend shock rod to check for abnormal resistance or noise. Push shock absorber piston rod in fully and release. Piston rod should return at a constant speed throughout its travel. If shock is defective, replace as an assembly.
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_725.jpg
Jun 30, 2010 at 10:40 AM
