1995 Toyota Camry Steering Column Vibrates at idle
1995 TOYOTA CAMRY
105,000 MILES • 4 CYL • 2WD • AUTOMATIC
GILLARSEN
When I am idling at a light, in gear with the brakes, on the steering column vibrates. A little less when shifted into neutral. Changed all motor mounts but vibration persists. Any suggestions?
May 12, 2008 at 12:33 PM
BMRFIXIT
  • 19,053 POSTS
start by looking for a vacuum leaks
clean idle air control valve
check EGR operation
is it due for a tune-up?
May 12, 2008 at 12:55 PM
