1995 Toyota Camry spark plug not burning gas
JEWBOY89
Engine Mechanical problem
1995 Toyota Camry 4 cyl Two Wheel Drive 98000 miles
ok the spark plugs are sparking but piston 2 and 4 arent sparking enough to burn the fuel and there is alot of fuel shooting though to those to pistons which is drowning them and the exhaust is spiting alotta gas out the back and there is water in the oil so im stumped. please help. thank you.
May 20, 2009 at 6:38 PM
KHLOW2008
  • 41,812 POSTS
Hi jewboy89,
Water in oil indicates a bad head or gasket.
Did you check the coolant level?
Do you have overheating issues?
With a bad head gasket, the comopression would be low and this would cause the cylinders not to fire correctly.
May 24, 2009 at 6:37 AM
