1995 Toyota Camry Shaking Alot
14,400 MILES • 4 CYL • 4WD • AUTOMATIC
KAMETRIA
I had taken my 1995 Toyota Camry to get a smog check and I failed.. I was told that my ECG valve was giving off too miuch gas, which makes my motor shake... Recently, I discovered I didnt have any oil in my transmissiion, so I poured oil in.. My car is still shaking when I put it in idle and when I reverse, it shuts off on me.... I really need some help.. please tell me what to do... I love my vehicle, toyotas are great cars, however, If I keep having the same issue, I just may have to get rid of it...
Oct 2, 2009 at 11:16 PM
  • 110,248 POSTS
The valve will most likely need replaced. As far as the trans, did you place the correct type of trans fluid in it.
Oct 5, 2009 at 12:13 AM
