1995 Toyota Camry Seatbelt No op
1995 TOYOTA CAMRY
18,500 MILES • 6 CYL • FWD • AUTOMATIC
SHAWNA2008
My drivers side seatbelt will no longer retract. I removed the panels and theres nothing visible stopping it. Is the problem in the seat belt assembly itself and is this a part that can be repaired? If a new part is required is it a dealer only purchase and can I install it myself. Are there safetly regulations on this part?
Thanks
Sep 14, 2008 at 5:07 AM
  • 31,937 POSTS
Hi there,
you will have to replace the seat belt as they are non repairable. you should never use a second hand belt as you don't know the history of it and it may have been over tensioned in an accident, replace with a new belt this is the only safe way to go. As long as it has no electric pre tensioner you should be able to do the installation your self.
Mark (mhpautos)
Sep 14, 2008 at 12:05 PM
