1995 Toyota Camry Radiator Overheating and Wipers will not
1995 TOYOTA CAMRY
184,000 MILES • 4 CYL • FWD • AUTOMATIC
TUCK520
At tiems thje vehicle the temperature gage reads hots and then the radiator begins to discharge thru the overflow thank for no real reason. Then the radiator is completely empty of all coolant. The radiator was replace witha used one from a 1992 Toyota Camry. What could cause this? The water pump, the radiator itself or the overflow tank?
2. Wiper will not turn off once they are turn on, unless you disconnect the wiper motor. Then it reset, but if you turn it on again then it starts all over.
May 11, 2009 at 3:50 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
With the cooling system you should first replace the thermostat, have the radiator cleaned & flow tested by a radiator repairer check that the pressure cap is working & holding pressure, check for any external leaks in the system with a pressure test and make sure that the cooling fans are working, also make sure that the A/C condenser in front of the radiator is not overly blocked and restricting air flow through it to the radiator, with the wipers i feel that the wiper motor self park function may be at fault, have this inspected as well.
Mark (mhpautos)
May 11, 2009 at 11:08 AM
