My radiator fan stop working causing my car to run hot.I change the sensor, but it still isnt turning. What is the problem?
Tuesday, January 26th, 2010 AT 8:06 PM
MECHANIC
Hi there,
Unplug the sensor and turn on the ignition, the fan should turn on, if not you will have to check voltage and earth at the fan motor, if this is ok, the fan has failed.
