1995 Toyota Camry Proper tire pressure
1995 TOYOTA CAMRY
BILLGATES88
Tires and Wheels problem
1995 Toyota Camry 4 cyl Two Wheel Drive Automatic
The maximum tire pressure indicated on my Micheline tires are: front 45, rear 35. What pressure should I maintain so it's the best for the running of the car and the wear and tear of the tires? Should I keep them different according the the specifications or should I maintain the same front and rear? Thank you very much
Sep 27, 2010 at 5:04 AM
PITCREW94
  • 18 POSTS
Why would you have two different PSI for the tire? Is all 4 of your tire the same size and brand? I would go with the Manufacture spec. But about 5 PSI less..
Sep 27, 2010 at 5:43 AM
