1995 Toyota Camry Power Steering Pump removal
1995 TOYOTA CAMRY
130,000 MILES • 4 CYL • FWD • AUTOMATIC
ROADS.ZX
What do I need to remove in order to access and remove the power steering pump?
May 1, 2010 at 3:00 PM
KHLOW2008
  • 41,814 POSTS
Hi Roads.zx,
Apart from the belting you need to disconnect the pressure and delivery hose, vacumn hoses and the holding bolts.
Space is rather tight and you might need to get under the vehicl for easier access.
May 1, 2010 at 3:27 PM
