1995 Toyota Camry Possible IAC?
270,000 MILES • 4 CYL • 2WD • AUTOMATIC
BROWNIZE1441
I was driving my 1995 Toyota Camry, and under heavy acceleration, the engine died. I was unable to re-start and had to have it towed. I replace the fuel filter, and this seemed to fix the problem initially, however it continues die after under heavy acceleration. I then cleaned the throttle body, but still have the same engine failure with anything more than very light fuel pressure. Suggestions?
Mar 30, 2009 at 5:56 AM
  • 75,988 POSTS
Check the fuel pressure/throttle position sensor/arflow meter
Mar 30, 2009 at 7:09 AM
