1995 Toyota Camry oil leeak
160,129 MILES • 4 CYL • AWD • AUTOMATIC
TERSON
i have a oil leak and i check a tech he said the valve cover gasket need to be change because the leak is on the back but the car is not hodingthe oil
Nov 15, 2008 at 12:20 AM
ZACKMAN
  • 4,202 POSTS
5SFE engine is prone to valve cover gasket leak. That leak causes the oil to foul the spark plugs, and then leaks out of the valve cover causing oil mess all over the engine.
Also, I would check around your crankshaft pulley and oil pan for possible leaks.
Nov 15, 2008 at 3:24 PM
TOYOTECH
  • 33 POSTS
5sfe engines with high mileage will typically leak from the valve cover gasket, distributor o-ring and seals behind the timing belt such as the cam shaft seal, front crank seal, oil pump shaft seal and oil pump o-ring. The spark plug tubes will fill up with oil possibly ruining your ignition wire set. A good cleaning then observation should show you where the bulk of your leaks are coming from.
Nov 22, 2008 at 4:10 PM
