1995 Toyota Camry my vehicle's gears wont engage
HAWAIIAN_4_TOYOTAS
Transmission problem
1995 Toyota Camry 4 cyl Front Wheel Drive Automatic
Hi...I have a 1995 toyota camry 2.2l i just did a recent motor replacement swap on it and everything works the only problem is my car wont engage into drive the car cranks over and the idle is good and strong...it will shift into drive...but itll just stay in neutral...im wondering what it my be???...it does shift and all electricals work it just wont drive...please help!!!
Jun 14, 2009 at 3:25 PM
  • 31,937 POSTS
Hi there,
Check the fluid level, check that the transmission is actually selecting drive, check that the torque converter is bolted up, check drive shafts are engaged into trans axle fully, start here.
mark (mhpautos)
Jun 14, 2009 at 10:36 PM
HAWAIIAN_4_TOYOTAS
for getting back to me ill do such
Jun 16, 2009 at 7:03 PM
