1995 Toyota Camry It could be a low oil perssure
SAMBARON
  • 1995 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 197,500 MILES
This car, despite the age and the high millage use to run like new, but now I start hearing almost clicking noises coming from behind the timing belt area. The timing belt was done about 60,000 miles ago and still look new. So I think it might be a oil pump that cannot produce high pressure anymore.
My question is: what pressure - in psi - normally it should be? And it its NOT the oil pressure, what else could it be?
Sunday, November 7th, 2010 AT 1:34 PM
Hi sambaron, Welcome to 2carpros and TY for the donation
Oil pressure at idle -should be 43psi and @ 3K rpm 36-71psi
Double check the idler and oil pump pulley-loose belt
Sunday, November 7th, 2010 AT 2:41 PM
