1995 Toyota Camry igniton problems (can't turn key)
RJRILEY13
Hello, I have a 95 Camry. One morning about 2 weeks ago my fiancee went out and the car wouldn't turn over (key wouldn't turn), it acted like the ignition was frooze. I called a local garage and they said to heat the key with a lighter. Did that and nothing. I went to the Toyota dealership and bought a new ignition switch for it and it worked great for about a week. We just had the problem happen to us again (even after we bought the new ignition). Please help!!!! Thanks Randy
Feb 15, 2007 at 10:10 PM
MIKE H R
  • 3,094 POSTS
my first thought, check the keys. if you had extra
keys made up they might be slightly off. if they are then the ignition won't turn. did that myself kept
trying to use old keys from old ignition switch.
Feb 16, 2007 at 3:17 AM
RJRILEY13
Nope, using the new keys. That's what I first said to her that she probably had the old keys. Then I tried it myself and still wouldn't turn. Have no idea....
Feb 16, 2007 at 10:15 AM
MIKE H R
  • 3,094 POSTS
check the keys to see if any has a tip broken. see if you can see anything in cylinder
Feb 16, 2007 at 11:57 AM
RJRILEY13
Keys are brand new and not broke, nothing in cyclinder.
Feb 16, 2007 at 10:52 PM
MIKE H R
  • 3,094 POSTS
Randy, one other thing to try before i suggest you take the ignition switch back our. try moving the steering wheel back and forth while trying the key. if
that does not work take the ignitind switch out and see if it turns while it is out. if defected take back to dealer and have it replaced. have seen where you could not turn key because of position of steering wheel.
Feb 17, 2007 at 12:04 AM
