Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Camry
Fuel System
Fuel Injector
1995 Toyota Camry fuel injectors
1995 TOYOTA CAMRY
100,000 MILES • 4 CYL • 2WD • AUTOMATIC
MLPRZYBYLA
MEMBER
1 POST
I am trying to lower the amount of gas the injectors are pumping into the chamber. Is there an easy way to do this
Mar 15, 2009 at 3:17 PM
Experienced Mechanic
Better check the pressure regulator if its functioning and the return line if its clogged-up
Mar 15, 2009 at 3:22 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
