1995 Toyota Camry Engine Missing
SALSERO328
  • 1995 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 230,000 MILES
My car just recently started to run awful, it is idling erratically and when I put it in drive it idles very low (almost shuts off but doesn't). Car has new spark plugs (old plugs showed no oil), new rotor cap, used another distributor cap (old but working), plug wires are ok, performed compression test ( all cyl at around 180), car not blowing white smoke, no oil in radiator, no water in engine oil, 3 months ago replaced radiator and thermostat, I have been losing a little oil due to rear main seal (needs replacement). The check engine has recently just turned on, code 401, check and filter and vacumn hoses ok, I believe that I hear an unusual hissing noise, I have check the throttle sensor? Loosen both screws and try to adjust, it can cause a change but car still missing, can you help please! Thanks in advance, fm
Friday, November 20th, 2009 AT 12:24 PM
Engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Friday, November 20th, 2009 AT 1:13 PM
