1995 Toyota Camry Electrical Problems
203,000 MILES • 4 CYL • FWD • AUTOMATIC
SIMPLYG
My windows don't work anymore. When I press the window controls the reverse (R) light comes on. To make matters worse when I turn my car on and turn the headlights on I cannot put the car in gear (it's locked). When I turn off the headlights then I'm able to put it in gear. While driving I turn the headlights on and the transmission gears down to first and will not shift to second gear also all the lights on the dashboard goes dim. What could be the problem? Please help!!
Dec 3, 2009 at 9:26 AM
DOCFIXIT
  • 18,828 POSTS
Hi
This one will be challenging so hear goes has there been any recent repairs? problem come on suddenly?
Any other electrical snafus? Behind the left kick panel is a ground connection with several black wire attached to body check to see if tight and clean.
Let me know
Thanks for donate
Dec 4, 2009 at 1:29 AM
