1995 Toyota Camry Collapsed Coolant Lines and Retarded Timi
166,000 MILES • 4 CYL • FWD • AUTOMATIC
SAMBOHH
On my way home Friday my Camry made an odd noise and lost low end power. I noticed that it was overheating. This happened less than a minute from my house, so I brought it home. When I popped the hood, I found the coolant lines collapsed. When I checked the timing, I found that it was about 15 degrees retarded. I have recently replaced the timing belt and water pump. I know the timing was set to 5 degrees advanced. I am at a loss... what would make the lines collapse? and at the same time wreck the timing? Maybe my tensioner broke? Help!
Jun 22, 2008 at 1:51 PM
BLACKOP555
  • 10,386 POSTS
the retarded timing could cause the vehicle to run hotter and cause the hoses to collapse from the high heat.
Jun 22, 2008 at 2:12 PM
