1995 Toyota Camry CAR TURNS OFF
143,000 MILES • 4 CYL • 4WD • AUTOMATIC
KIRIALEGER
HI,
I START THE CAR WITH NO PROBLEM BUT AFTER DRIVING FOR A COUPLE OF MILES IT WILL START PULLING AND TURNS OFF. I CHANGED THE GAS PUMP AND FILTER I ALSO CHANGED THE IGNITION BUT I STILL HAVE THE SAME PROBLEM. I WAS PLANNING TO TAKE IT TO A COMPUTER DIAGNOSTIC PLACE BUT I WA TOLD THAT ONLY WORKS IF THE SERVICE ENGINE LINE IS ON BUT IT'S NOT. WHAT CAN I DO ? WHAT COULD IT BE?
Mar 17, 2009 at 12:04 PM
JOE C.
  • 25 POSTS
you said you changed the ignition. what part of the ignition system did you change?
Mar 18, 2009 at 12:33 AM
