I start drive the car has like a lag keeping up with traffic?
MMCK2K9999
When I start drive the car has like a lag keeping up with traffic, I need to press the gas pedal all the way down. It has a hard time starting from a stop light. I replace spark plugs, clabes, rotor and cap all oem thinking it would help. I change the air filter and a defected air hose that connects from the intake manifold to the airfilter box it accualy made it worse. Do I need to change the fuil filter? please help asap.
Jul 31, 2010 at 12:54 PM
SQM
  • 6,383 POSTS
Poor acceleration can be caused by a clogged fuel filter. So, changing that is a good idea.
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
However, what you are describing sounds like the timing belt might have gotten worn and skipped a tooth. Which is making it difficult to accelerate. I have seen this happen before that a faulty timing belt can impact acceleration. And typically, it will do that before it breaks.
https://www.2carpros.com/articles/how-a-timing-belt-works
Dec 19, 2021 at 10:55 PM
