Hi g1knj99,
When you are able to jump start, that indicates a problem with the battery.
Some batteries can show a full charge but when the starter is being cranked, the voltage would drop.
Attach a voltmeter to the battery and while ignition is turned to START, note if the battery voltage level drops below 10 V. If yes, the battery is bad.
SPONSORED LINKS
Thursday, February 25th, 2021 AT 4:07 PM
