1995 Toyota Camry Accelleration
FEMALEDEER
  • 1995 TOYOTA CAMRY
Engine Performance problem
1995 Toyota Camry 6 cyl Automatic 235000 miles
This doesn't happen all the time, but sometimes my car has trouble accellerating - it can be on a flat road, or a hill, just all of a sudden it goes extremely slow even if I put the gas pedal to the floor. Any suggestions?
Friday, July 17th, 2009 AT 10:15 PM
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Friday, July 17th, 2009 AT 10:23 PM
