No gas pedal until I press it twice in the Morning
MR_K
  • 1997 TOYOTA CAMRY
  • V6
  • 195,000 MILES
Morning car is slow to go. I put gear in drive and car will not move. Will have to let up on gas pedal then press down again. Then car runs great. Suggestions?
Sunday, August 21st, 2016 AT 6:45 PM
HMAC300
  • 48,601 POSTS
Check transmission fluid for being low then have a transmission professional look at it. May be time for a rebuild.
Monday, August 22nd, 2016 AT 8:13 AM
MR_K
Thanks HMAC300. Will take it to favorite local mechanic but he just did oil change, which usually incudes fluid check. Would a rebuild be worth it you think? About 200,000 miles and peeling paint. Only paid $2500 for it 2 years ago. Love the car but may just run it to the ground - no other troubles except will buy a new axel when steering stiffens up in a few months. Thanks.
Monday, August 22nd, 2016 AT 8:04 PM
HMAC300
  • 48,601 POSTS
The worth it thing is up to you I never give advice on this unless I know the car. It will be about 1500-2000 for a rebuild or check around or maybe one from a junk car for cheaper.
Tuesday, August 23rd, 2016 AT 7:14 AM
MR_K
Sounds good. Will get an estimate this week. Thanks.
Tuesday, August 23rd, 2016 AT 2:05 PM
MR_K
To HMAC300. My mechanic said just let it warm up in the morning. At its age, it's not worth a rebuild. Thanks.
Thursday, August 25th, 2016 AT 10:13 PM
RENEE L
  • ADMIN
  • 1,260 POSTS
Thanks for using 2CarPros please come back with any others problem you may have we are happy to help.
Tuesday, August 30th, 2016 AT 10:04 AM
