1995 Toyota Camry
165,000 MILES • 6 CYL • 2WD • AUTOMATIC
WORLDARENA
Replaceing spark plugs on a 1995 camry. How do you get the cover off to get to the plugs?
Feb 22, 2009 at 3:37 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:295fe20c9c="worldarena"]Engine Performance problem
1995 Toyota Camry 6 cyl Two Wheel Drive Automatic 165000 miles
Replaceing spark plugs on a 1995 camry. How do you get the cover off to get to the plugs?[/quote:295fe20c9c]
All you need to do is pull plug wire off and use extension with the spark plug socket to reach down to plug. You do not need to remove the Valve Cover.
Feb 22, 2009 at 4:00 AM
