1995 Toyota Camry
1995 TOYOTA CAMRY
200,000 MILES • 4 CYL • 2WD • AUTOMATIC
FABIAN GUERRERO
, the transmision won't shift right away but once it does it works fine without the the odemeter ,speedometer,rpm guage,fuel guage do not work i already check all fuses
Nov 30, 2008 at 12:44 PM
  • 31,937 POSTS
Hi there, have a transmission service done this may help the shifting problem, as for all the dash gauger's, i have had cars with a problem with the circuit board in the dash, you may want to try a second hand dash this may fix your problem there.
Mark (mhpautos)
Nov 30, 2008 at 12:51 PM
