1995 toyota camry
CAMICHAE
1995 toyota camry 152,000 ml 4 cyl, Need help trying figure out why it will not start, the fuel pump and filter is ok, the ignition ignitor was replaced, New battery, new radiator, new oil pan gasket. It was running fine then it sputtered and stopped running. Its turns over but will not start, please help :x Im almost out of hair. Thanks
May 29, 2006 at 2:48 PM
LOSONE
  • 1,616 POSTS
You first have to determine if you have fuel and spark. If you have both then you have to see if you have an injector pulse.
If you have that then you need to check and see if you have correct timing. That means your timing belt hasn't slipped a notch or two.
Jun 1, 2006 at 8:27 AM
