1994 Toyota Camry WARNING LIGHTS
188,000 MILES • 6 CYL • FWD • AUTOMATIC
EICI075
The check brake lights warning light is on even though all the lights are working & when I press on the break pedal, the R(reverse) light comes on the dash. When I'm stopping, and get to around 20 miles per hour there is a shimmy in car & the brakes seem to grab
Sep 11, 2008 at 9:47 AM
KHLOW2008
  • 41,812 POSTS
Hi eici075,
For the brake and reverse lights you need to check for a bad ground at rear tailight.
The brakes grabbing could be due to excessive clearance at the wheel bearings, check if any is faulty.
Sep 27, 2008 at 10:47 PM
