I need to know the procedure for adjusting the nuetral safety switch.
Sunday, December 9th, 2007 AT 8:18 AM
KNOBBY
MEMBER
Why do you need this info what is wrong there is no ajustment
Sunday, December 9th, 2007 AT 8:28 AM
KEN L
MASTER CERTIFIED MECHANIC
The best way to adjust the switch is to get a clean neutral, set the parking brake and loosen the hold down bolts, then put the car in neutral and adjust the switch so the starter works and then tighten it down and you should be okay.
