1994 Toyota Camry right rear window
20,000 MILES • 4 CYL • FWD • AUTOMATIC
GOUVEIA
I just changed the right rear window motor and regulator, put everything back together and turned on the car to roll up the window. The window rolled up one time and now it's the same as before i changed it. It won't go up or down. What could be the problem??
Mar 21, 2010 at 3:36 PM
BMRFIXIT
  • 19,053 POSTS
Check master switch and door switch check wiring
remove window motor connector plug and use a test light in-between
it should light up when selected up and down if so defective motor if not check wiring in door jam and switches
Mar 21, 2010 at 11:06 PM
