1994 Toyota Camry RIGHT driveaxle
120,000 MILES • 6 CYL • FWD • AUTOMATIC
TAVOBORREGO
I've followed the steps in the service manual to remove the RIGHT driveaxle from my 1994 Toyota Camry but it won't budge!! I've pryed and pulled as hard as I can with no luck. Please HELP! Is there a trick or something that I can do to remove it? Respectfully, Tavo.
Feb 6, 2008 at 5:52 AM
2CARPRO JACK
  • 11,533 POSTS
From the transaxle? Need to get a pry bar behind it and pop it out. Sometimes if you can get a bar under each side you can pry side to side and get it to pop out
Feb 7, 2008 at 3:57 AM
