1994 Toyota Camry OBDII Code P0773
165,000 MILES • 6 CYL • FWD • AUTOMATIC
JPP44345
  • 6 POSTS
What is shift solenoid E problem? And what is the repair procedure? Can this be done at home? It comes and goes once in a blue moon so should I even bother?
Dec 11, 2009 at 12:29 PM
MATHIASO
  • 1,209 POSTS
The shift solenoid E is an internal transmission part. Shift solenoids are activated to change gears. When not activated, there is no gear change.
To locate the solenoids, the transmission pan must be removed.
Repair procedure depends on the actual problems.
Is it electrical? Or is the solenoid leaking?
When you remove the transmission Pan, there is a bunch of solenoids( A, B,... E)
Dealer has equipments of diagnosing properly malfunctioning solenoids.
Dec 12, 2009 at 2:59 PM
JPP44345
  • 6 POSTS
The engine light comes on and when i scan it it says shift solenoid electrical. so it is an electrical problem. gear change are for the most part smooth except for reverse.
Jan 4, 2010 at 10:10 AM
MATHIASO
  • 1,209 POSTS
The solenoid E should be responsible for the valve that is in fact for the reverse . Dealer has solenoid tester to identify the problem,transmission must be removed/lowered before checking for an open or shorted circuit.
the good news is there won't be no need to rebuild the transmission, it just an electrical problem.
Jan 4, 2010 at 5:52 PM
JPP44345
  • 6 POSTS
Is there a cabin air filter on a 1994 Toyota Camry XLE V6 and if yes, where is it?
Jan 8, 2010 at 3:20 AM
MATHIASO
  • 1,209 POSTS
Hello jpp44345
There is no cabin air filter on your 1994 Toyota Camry XLE V6 .
Cabin air filters were introduced back in the mid-1980s in Audis and other European luxury vehicles
. The first domestic applications date back to 1994 (Ford Contour & Mercury
Mystique). Today, cabin air filters are found in almost 80% of all new vehicles
The best way to determine if your vehicle has a cabin air filter is to check your filter supplier's catalog or database, or to look in the vehicle owner's manual. Check the index for Cabin Air Filter, or look in the section that lists scheduled maintenance items.
I checked and could not find cabin air filter on your vehicle.
Jan 8, 2010 at 5:04 PM
