1994 Toyota Camry NO PRESSURE ON CLUTCH PEDAL
1994 TOYOTA CAMRY
259,991 MILES • 4 CYL • FWD • MANUAL
GARYKCSR
I HAVE NO PRESSURE ON CLUTCH PEDAL WHEN I PUSH IT IN TO CHANGE GEARS ALSO STUCK IN FIRST GEAR
Jun 18, 2010 at 7:33 AM
DOCFIXIT
  • 18,828 POSTS
Check fluid in clutch master cylinder. Either master or slave cylinder on trans has failed.
Jun 18, 2010 at 8:16 AM
FORDRACING24
  • 65 POSTS
You could also have broken the fork which releases the clutch from the transmission which would cause the car to start but be stuck in first. Happened to a friend of mine
Jun 18, 2010 at 9:08 AM
