HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Camry
Drivetrain
Transmission
Gear Position Sensor
1994 Toyota Camry neutral safety switch
HATRICK
MEMBER
1994 TOYOTA CAMRY
Transmission problem
1994 Toyota Camry 4 cyl Automatic 278 miles
how can I bypass neutral safety switch to see if that is the problem
Wednesday, March 3rd, 2010 AT 5:45 PM
BLUELIGHTNIN6
MECHANIC
Try starting vehicle in another gears, if vehicle starts in other gear besides park / neutral then its bad. also very easy to test the switch. just takes a 12v tester. more info. on neutral safety switches can be found at light
https://www.2carpros.com/how_does_it_work/how_a_neutral_safety_switch_works.htm
Wednesday, March 3rd, 2010 AT 6:25 PM
Please
login
or
register
to post a reply.
Related Transmission Gear Position Sensor Content
1994 Toyota Camry Gear Switch Adjustment
I Think I Need To Adjust The Park/neutral Switch, But Can't Seem To Get The Plastic Housing Up So That I Can Get Into The Bolt In Order To...
Asked by
cyrilghartman
1 ANSWER
2 IMAGES
1994
TOYOTA CAMRY
GUIDE
Neutral Safety Switch Test
The functionality of the neutral safety switch has changed greatly through the automotive development era, what was once a simple switch for the reverse lights and starter...
Do You Think The Transmission Need To Be Replaced Or...
When I Put My Car In Reverse It Will Not Go Back As It Should, It Wont Do Anything. On A Hill Its Tries To Go Back But Its Like Something...
Asked by
jsmith12
1 ANSWER
1 IMAGE
1994
TOYOTA CAMRY
1994 Toyota Camry Transmission Seals Are Linking
Hi: I Have A 1994 Camry And I Have Noticed Over The Past 4-5 Days, Only In Early Morning, The Car Is Very Sluggish When Moving From...
Asked by
ssriniv1
1 ANSWER
1994
TOYOTA CAMRY
Has Po770 Shift Code. Engine Light On Car Drives...
Has Po770 Shift Code. Engine Light On Car Drives Fine. But Change Tranny Fluid Look For Meta, Tl Looked Ok No Loose Wires Did Not Do...
Asked by
Anonymous
1 ANSWER
1994
TOYOTA CAMRY
1994 Toyota Camry
Transmission Problem 1994 Toyota Camry 6 Cyl Automatic 242000 Miles My O/d Sensor Blinks When It's On And Stays Lit When It's Off. I...
Asked by
Jdilan
1 ANSWER
1994
TOYOTA CAMRY
VIEW MORE
Starter Not Working
Car Not Cranking? Try This | EASY
How to Use a Test Light
