1994 Toyota Camry My Blinkers refuse to work, But the hazar
1994 TOYOTA CAMRY
200,000 MILES • 4 CYL • 2WD • AUTOMATIC
FRITZIE555
My Cars blinkers recently stopped working. It happened two weeks after a fender bender i was in, it made it so the blinker bulb was exposed. so after a while the right bulb was broken but the left side blinker still worked. but shortly after both sides still won't work. When i checked out the broken bulb the two wires that normally hold the filament where bent together and touching. I have replaced the flasher and bulbs and i have not been able to figure out if there is a hidden fuze somewhere. all the fuzes that i know are their are intact including the one next to the flasher. Now everything on car works and is fixed but blinkers still won't work. Please help, it would be greatly appreciated =) thank you.
Mar 15, 2009 at 4:48 PM
Turn signal fuse 15 amp no.19
Turn Signal Flasher On fuse/relay block No. 6, above glove box
Mar 15, 2009 at 5:35 PM
Both turn signal flasher and fuse good -test the combinationl switch
Mar 15, 2009 at 5:43 PM
