1994 Toyota Camry locking
211,119 MILES • 4 CYL • FWD • AUTOMATIC
RICKYLEE1
What causes my front brakes to try to lock for short periods then release?
Dec 11, 2009 at 3:10 AM
  • 31,937 POSTS
Hi there, often this can be sticky brake calipers, or faulty brake hoses, but if both are doing it at the same time, you may have a problem with the master cylinder or proportioning valve, you will have to check out if it is a hydraulic or mechanical problem first, if you can crack a bleeder when the brakes are locked, if fluid releases and the brakes back off, this will normally be a hydraulic problem.
Mark (mhpautos)
Dec 11, 2009 at 6:44 AM
