1994 Toyota Camry idle adjustment
214,000 MILES • 4 CYL • FWD • AUTOMATIC
LJZ
my car shuts off when i give gas. i would like to know where the idle adjustment is. the rpm is under 1000, is that good?
Jun 4, 2010 at 1:52 PM
  • 75,988 POSTS
You need to uncap the air valve adjustment screw on the throttle body and jumper Te-1 to E-1 in the check connector then drop the idle to 800rpm.
Jun 4, 2010 at 1:58 PM
