Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Camry
Engine
Idle Air Control
1994 Toyota Camry idle adjustment
1994 TOYOTA CAMRY
214,000 MILES • 4 CYL • FWD • AUTOMATIC
LJZ
MEMBER
1 POST
my car shuts off when i give gas. i would like to know where the idle adjustment is. the rpm is under 1000, is that good?
Jun 4, 2010 at 1:52 PM
Experienced Mechanic
You need to uncap the air valve adjustment screw on the throttle body and jumper Te-1 to E-1 in the check connector then drop the idle to 800rpm.
Jun 4, 2010 at 1:58 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
