1994 Toyota Camry Humming noise in front suspension
FG MAK
  • 1994 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 136,000 MILES
My camry lately as I increase spead above 60mph starts to hum the faster I go the more rappid the humming almost like the front wheels are struggling greatly. I was thinking it perhaps was a wheel bearing problem?
Wednesday, April 29th, 2009 AT 8:00 AM
MMPRINCE4000
  • 8,548 POSTS
Start by doing this:
Raise car, put on stands. Grasp tire and push/pull both horizontally and vertically, if any movement then possible wheel bearing, ball joint, tie rod, control arm bushing.
Check CV boots for any signs of leakage or cuts/rips in rubber boot.
It is also possible that it is the tire. If the above checks out OK, the move front tires to rear RF to RR and LF to LR. If noise moves to rear, then tire is problem.
Friday, December 11th, 2020 AT 12:49 PM
