How do I replace air filter on a camry. I have already purchased the FRAM CA7351 AIR FILTER
Wednesday, April 23rd, 2008 AT 1:16 AM
MECHANIC
Hi there,
Just un-clip the air filter top cover and hold clear (you can undo the air induction pipe at the throttle body if you wish and remove the entire assembly) lift out old element, clean muck from bottom of air box fit new element and re fit air bot top.
