1994 Toyota Camry How to replace a wheel stud in 1994 Toyot
220,000 MILES • 4 CYL • FWD • AUTOMATIC
DB2010
  • 6 POSTS
I have already taken off the right front tire, caliper, rotor, axle nut to get to the axle hub. Now I am not sure if I need to remove an axle hub to get the studs out or I can just hit hard with a hammer on a stud while it is on the car for it to come out?
Thanks for you answer in advance
Oct 25, 2010 at 5:54 AM
F4I_GUY
  • 3,302 POSTS
Just hit the stud hard until it drops out. Try rotating the hub to get the easiest location to remove the stud.
Sometimes it is necessary to grind a small amount off the head of the stud for install.
Oct 27, 2010 at 3:21 AM
