1994 Toyota Camry help sometime it run and sometime it dont
257,568 MILES • 6 CYL • FWD • AUTOMATIC
PHIL37380
u can drive down the road and the motor stop runing and want start back. u can wait 30 or 40 min. and it starts up and run again. put new fuel pump on still have problem it a daily thing with car
Feb 9, 2010 at 3:59 AM
  • 75,988 POSTS
Don't wait for nothing,do below immediately to determine whether it's a fuel or spark problem.
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Feb 9, 2010 at 8:13 AM
