1994 Toyota Camry fuel system
ENIAH
1994 Toyota Camry 4 cyl Two Wheel Drive
I have changed my plugs and made sure I had the right gap. But I am using a lot of fuel and it hestates when I am driving and excelerate
Sep 16, 2010 at 9:37 AM
  • 75,988 POSTS
Lack of acceleration,chugging,hesitating,jerking,bogging,misfiring etc. could be caused by one of the following below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Sep 16, 2010 at 9:44 AM
