1994 Toyota Camry Crankshaft Pulley Replacement
285,000 MILES • 4 CYL • FWD • AUTOMATIC
RALIVATSEVA
I don't know how this happened and I've never seen it before, but the pulley attached to the crankshaft slid out away from the crankshaft. Now I don't know if the entire thing needs to be replaced or not. We pushed it back in with a hammer, but when we try to tighten the nut in front, we can't because the crankshaft turns with it. How can we stop the crankshaft from turning in order to tighten the pulley? Do you think the pulley is broken because it came out like that? We first noticed because the alternator belt kept falling off. We replaced it with new one, but still falls off and then we realized that the pullies were not alligned.
May 14, 2008 at 5:52 AM
  • 31,937 POSTS
Hi there,
Just do it up as tight as you can & drive to a work shop and get them to tighten it up with an impact gun, this will take about 1 Min to do.. Or you will have to remove the starter and lock the ring gear with a suitable lever.
Mark (mhpautos)
May 14, 2008 at 4:23 PM
