Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Camry
Trouble Codes
OBD1 Codes
Code 13
1994 Toyota Camry code 13
1994 TOYOTA CAMRY
78,000 MILES • 4 CYL • FWD • AUTOMATIC
42HOTROD12
MEMBER
has code 13 replaced distributor checked wiring and connectors to ecm
is a bad ecm common on this car?
Oct 9, 2009 at 9:10 AM
Experienced Mechanic
DTC 13 G, NE Signal Circuit No. 2.
Distributor has been replaced wiring has no open or short circuit-last place is the ECM either you swap or replace it-and see what happens
Oct 9, 2009 at 10:17 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
